Deletes an IP Network Address Translation (NAT) rule.
| ip | Specifies Internet Protocol (IP). |
| nat | Specifies NAT. |
| rule | Specifies deleting a NAT rule. |
| rule_name | Specifies the NAT rule name to delete. |
N/A.
To create a rule, run the command create ip nat rule rule_name type [ source-nat | napt | destination-napt].
The following example deletes the NAT rule named "rule1"
# delete ip nat rule rule1
This command was first available in ExtremeXOS 31.2.
This command is available on the switches that support the IP NAT feature. For information about which switches support this and other features, see the Switch Engine v33.1.1 Licensing Guide document.
